Image_Engine
How do you force S3d to not leave large hole(s) in the model?
Im doing tests before committing a large print
I run corkscrew mode and it leaves large gaps like this
Why does S3d not create a warning
How can you force settings on these areas to correct the gaps
Thanks
Re: How do you force S3d to not leave large hole(s) in the model?
You could try the adaptive layer height feature, which will lower the layer height in those regions so that there is less of a stepover between layers.
If that doesn't work, you would probably need to start adding some top solid layers instead.
