knutselsmurf
scaling objects: possible but no size measurements visable?
Another importent option which is not buildin yet: when you scale an objects, you want to see the size measurements, not only the percentage?? Ok, there is a MESH window, but that is not the same..
Re: scaling objects: possible but no size measurements visable?
If you double-click on the part, it will display the Model Transforms dialog which shows the size of the part. You can edit the size there if you want to resize the model to some exact dimension.
