3DPotter
Vase mode Z travel on 1st and 2nd layer
Is there a way to not have a strong "plowing" effect through the 1st/2nd layer on vase mode? (video)
https://youtu.be/oYElndNqwvw?si=AKnT1gPNNfe_9w2i
Ideally, is there a plugin or some custom script code available to have a transition like the following pictures?
Image Image
This is for 3D printing cement with a 3/4in nozzle size.
Simplify 3D 5.1.2
Factory file attached.
bench_v4 whole file.factory
(66.57 KiB) Downloaded 148 times
https://3dpotter.com/
https://www.instagram.com/3dpotter/
https://www.youtube.com/c/3dpotter/
https://www.facebook.com/3dpotter/
Re: Vase mode Z travel on 1st and 2nd layer
You could always use the variable settings wizard to create a separate process for the first few layers. That way you can use whatever printing style you want before you begin the spiral.
