kent999
More extrude on top..?
Hi.
If I want 10% more extrude there on the arrows, which boxes should I click in vers. 5.0 . name on it?
S3D-Taylor
Re: More extrude on top..?
If your normal extrusion multiplier is 1, then using 110% for the 'Top Layer Extrusion Modifier' should do that. Remember, you can do a search for any of these settings from the top right corner of Edit Process Settings.
kent999
S3D-Taylor wrote: ↑Wed Jan 24, 2024 10:53 am Hi,
Thanks for the reply Taylor.. does the top belong to the "top layer"?
Isn't this actually a "wall"?
Elephantbody i "round"
So I don't miss anything..?!
TheBum
Even a curved top consists of overlapping layers. Any horizontal surface that is visible outside the model is a top layer.
