RLGL
Want to add pre-extrusion g-code
I have a Flashforge CreatorPro 2 / CreatorMax2 printer. It has 2 extruders. I want to add code for pre-extrusion for either the left or right extruder to the starting script. This is to make it follow the outline of the print at an offset of X mm and a length of X mm. I am using Simplify3d version 5.2.
TIA
Re: Want to add pre-extrusion g-code
One easy way to prime both extruders is to just enabled the skirt addition in S3D. You can set the skirt to use "All Extruders" and then it will draw a loop with each extruder to make sure they are all fully primed.
