Brimo60
Simplify3D support for Elegoo Neptune 4 MAX
I am considering purchasing an Elegoo Neptune 4 MAX, but I do not see currently available settings for Elegoo Neptune 4 MAX.
There are 3, 3 Pro, 3 MAX, 4, and 4 PRO settings.
Only the 4 MAX isn't listed.
1) Is there any chance it will be included shortly?
2) In the meantime, what would be the closest setting to use instead? 3 MAX or 4 PRO?
(note - PRO and MAX are just different bed sizes, but between 3 MAX AND 4 PRO lines, there are significant speed improvements and additional cooling (that also reduces the Zmax from 500 mm to 480 mm)
Any tips or bits of advice are greatly appreciated.
Re: Simplify3D support for Elegoo Neptune 4 MAX
Please contact our team directly at the link below and they can assist you with the profile:
Powie
I emailed support as well. How about network connecting to the 4 Max? Is that possible?
The Neptune 4 Max runs Klipper and Simplify3D V5 already supports network connections to Klipper-based printers. You should be able to use the included S3D Connection Wizard to setup a connection to the printer.
Powie
Thanks, yah I got it to manually connect, didn't realize it actually connected at first because the printer just spews so much XML where the Octoprint printers I have are quiet. I've not actually printed to it yet, but it did connect
Glad to hear that you were able to connect and that it's working correctly!
