lena_di
print height limited
Hello, I would like to print my object with a specific height, which i have defined in the advanced process settings by "stop print at height 50mm". Funnily, the print preview and the print itself only reach a heigth of 1.4mm maximum. Just for fun, I changed the layer height, the height of the object, the extruder width and z-axis-offset, but it does not make a difference. The maximum print height is 210mm.
Anyone an idea what I'm missing? Thanks in advance!
S3D-Taylor
Re: print height limited
You could attach the factory file here. The Factory File is a unique file compiled in Simplify3D. The file contains complete information about your project (model, printer, process settings, etc.). To create the file, open the software and load your project. Then go to File > Save Factory File as...
