sebastian.heyn
different folder memory for Import/Export dialogue
When slicing many files at once, the following happens.
Lets say my STL files are at following position
x:\stl files\subfolder\subfolder\project\
and my gcode should be stored
dekstop:\gcode files\
after storing the gcode to the desktop folder, s3d forgets the import folder. Especially, when there is a lot of subfolders involved, its sometimes painful when trying to slice many stl files in a batch.
maybe there is some time to implement 2 different folder memories in some future revision.
Thanks in advance
Basti
S3D-Taylor
Re: different folder memory for Import/Export dialogue
You should be able to do this by going to Tools > Options (or Simplify3D > Preferences on Mac), then change the File Selection Behavior to ‘Remember a unique last used directory for each separate file type’.
