eugenewright
Limited Global G code Offset issue
Max offset one can enter is 99.99 mm.
So how can I print say only the top 25 mm of a item that is say 200 mm high when max global g code offset is 99.99 mm?
Maybe there is a different way?
Any suggestions are very welcome.
S3D-Taylor
Re: Limited Global G code Offset issue
Using Custom Zones would be a better idea. It is in the bottom left corner of Edit Process Settings.
