phillipsmall
Simplify3D print issues
OK, so I have been having a fit as of late with Simplify3D and printing objects. I slice them, send to the printer, and things start out ok, but then it knocks them loose during the print, so i have to cancel the job. If I slice with Slic3r Prusa Edition, and try, they print out without issue. Anyone know what is going on with Simplify3D?
I previously had it working, but had to remove it and reinstall and since then, it is failing like this on everything I've tried to print.
geometry dash lite
I am using all the defaults, and printing in PLA, so should be pretty standard and easy.
S3D-Taylor
Re: Simplify3D print issues
Could you attach a factory file here so we can take a look at it?
