OPM
Alternate multiplier for infill?
Hello,
Is there a way to adjust the extrusion multiplier only for the infill portion?
Using adaptive layers, I find it becomes very sparse in there...
Thank you!
S3D-Taylor
Re: Alternate multiplier for infill?
You can use the concept of virtual extruders to do this. Essentially, this is the process:
1. Add an extruder in the Extruder tab and name it something like "Infill with different multiplier"
2. Set the Extruder Toolhead Number to be the same as the existing extruder
3. Adjust the Extrusion Multiplier for that.
3. Go to the Infill tab and select the virtual extruder in the Infill Extruder dropdown
OPM
"The concept of virtual extruders". Thank you so much for that!
