Assuming you would like to pause at a certain height and do the filament change manually, there are primarily two recommended methods.
Depending on the firmware, different commands might be used. The most common commands are M0, M1, M600, M601 for Marlin, PAUSE for Klipper, QIDI, CrealityOS, M400 U1 for BambuLab.
Method 1 (useful if you just want to change color, keeping all other settings the same):
Place the following in the Pre Layer Change Script (### is the layer you wish to pause at):
{IF "[current_layer_number] == ###"}M600
Method 2 (useful if you would like to use different settings for the new filament):
Going to Tools -> Variable Settings Wizard, select 'Different settings for different Z-ranges'. You can then add change in processes at different z-heights, this will create multiple processes. Then, in the second process go to Scripts -> Process Change, and paste this:
M600
