stepman91
[ADDED] Rostock MAX v2 Desktop 3D Printer
Hello !!
How are you ?
I would to know if you have the compatibility with the Rostock MAX™ v2 Desktop 3D Printer , I love you software and I use it successfully with a Flash Forge Creator Pro.
And I would like to buy and start the Rostock Max V2 kit , only if I can keep using simplify ;-)
Thanks for answer and keep make this Awesome !!
:D :D
Bastien
Picaflor
Re: Rostock MAX™ v2 Desktop 3D Printer
Hi Bastien
As I can see in the list, the Rostock Max V2 is supported.
https://www.simplify3d.com/software/supported-printers/
:P
Roger
bubbasnow
v2 uses RAMBo, so yes this will work with V2... I am using it with a V1
JFettig
Yup, I'm running it with mine however I never print from the PC, always print from a SD card for better reliability.
mvansomeren
I just purchased S3D and I'm running it on my PC and driving my Rostock MAX V2. So far so good....
___________________________________________________
Proud owner and builder of the Rostock MAX V2
As of version 3.0, there is also now a pre-configured profile specifically for the Rostock MAX v1 AND Rostock MAX v2. So just select your printer and you're good to go!
