Colen Casey
[ADDED] Add and edit materials support
where the Auto-Configure for Material
choices are under the extruder tab I would like a drop down instead where we can add in differnt materials, give them names and set all the parameters in the Process and then save it
then you can go back pick it and ALL the parameters are there for all the tabs
as it is now i'm limited to 4 materials and if I edit something under one of the tabs it applied to all the materials
This really doesnt work well for me as I waste time editing before I can print
Re: Material support
You can actually do this right now, you just make your own autoConfigureMaterial section. If you have never edited the S3D profiles before, you might want to start by reading this: http://forum.simplify3d.com/viewtopic.php?f=8&t=1989
Version 3.0 has now made this much easier. You just click the "+" button beside the list of material choices and pick a name for the new material you want to add. If you make a change to one of the materials (i.e. changing the temperature for PLA to 195C) the software automatically remembers that as well.
