Hello Clayton,
Thanks for looking at the bed levelling issue and for creating a wizard for this process.
However, I would like to make some suggestions for the manually defined levelling positions section of the wizard. Could you add a Z co-ordinate column? This will allow the user to input an offset that will prevent the extruder dragging across the glass when initially levelling the bed.
Also, rather than having to go to each point sequentially, could you allow the location to be selected from the list shown in the manually defined levelling positions window? I like to get the bed level across the Y axis first, and I have to repeatedly move between two co-linear points until the y axis is level, as a “seesaw” effect occurs when you tighten the levelling screws. Then I repeat the process to level across the x axis. Being able to select which point to send the extruder to would be much more efficient
Also, I would still like to see a few more macro buttons, they are very handy
Thanks for an excellent product, it just keeps getting better!
Steve.
