behold3d
solid layers problem
I have a model that when sliced produces a solid layer every so often. I do not want that to happen. What is causing this? i've included the gcode from simplify3d
Left Helix 2 Turn.gcode
(18.32 MiB) Downloaded 268 times
Re: solid layers problem
You will need to post the factory file if you want help with this. It is usually a mesh issue.
behold3d
no, i was able to get it working with cura. It was most certainly a simplify issue
behold3d
I also cant post the file since its under NDA
behold
This sounds idiotic now espevially since I posted the file already.. Oh well
its a problem with the model. all slicers pick up model error differently. solid layers or odd patterns in solid layers or solid layers where they dont belong is always a problem with the model.
