Rebekah_harper
concentric internal infil v3.0
hiya,
I had to use the now old v2.2 to achiceve a successful print.
for some reason you deleted the concentric internal infill option yet it's there for external??
please bring it back.
Becky
THW10_030a-TIRE LEFT SIDE.stl
if you are wondering what I am trying to print
(2.61 MiB) Downloaded 225 times
Re: concentric internal infil v3.0
No version ever allowed you to do concentric infill for the INSIDE of the part. Version 2.2 and Version 3.0 BOTH allow you to do concentric infill for the outer solid layers. So no functionality was lost at all between the two versions.
If you want concentric infill for the INTERIOR of your part, you are welcome to request that as a new feature, although, I have no idea why you would want that. The other internal infill options would work much better.
Carlos
did you try to set the infill to 100%? For me printing Ninjaflex with concentric infill works like a charm and the whole part gets a solid concentric infill.
If this is not what you need, could you explain or do you have pictures on how you used the concentric infill in the old version?
Regards
Carlos
Regards
Carlos
______________________________
Simplify3D v3.0 on Creatr HS
Olestra
concentic infill of 100% could be accomplished by setting the # top and bottom layers.
