OK, I'll admit, I've done a quick search of the forum, a quick test of the software and quick perusal of the quick start guide. Emphasis on quick so I may have missed some of the obvious things.
1. There seems to be implication that the profiles are saved to the cloud. However, when I setup my custom printer on my second computer, there appeared to be no synchronization. Am I missing something?
2. What's the best practice for dual extrusion? With 2.X, I had a process setup for Left Extrusion, Right Extrusion and Dual extrusion. I can do the same here but the filament profiles will overwrite the temperature settings for the disabled extruder. Should I make duplicate machine profiles? I'd like to avoid manually tweaking settings all the time and keeping those parameters synchronized. I can make do but I'm hoping someone has figured out better practices.
3. Is there a list of which variables get saved under which category (filament/quality/global)? Is there any way to petition for a change? Initial layer height appears to be global but because it's a percent, it would make sense to have it mirror the quality setting. I usually have my initial layer height to 0.3mm (I have a very large machine) and it's annoying to have to set it to 300% at high quality 200% at medium quality etc manually every time I change quality.
