mmcginnis9272
Scripting placeholder not working
So I have a CubePro Trio with the following in the Tool Change Script. When the Final .gcode is created, everywhere that [current_Z_position] apears, it is not being converted to the z position. The string [current_Z_position] remains in the gcode. Is there a trick to getting Simplify 3D to actually convert the placeholder into the Z value? I have attached my Factory file as well.
^Changing Tools
^ABS_Temp_220_250
^ABS_Temp_220_250
^Current_Tools 1-ABS
^2-ABS
^3-ABS
^Shut off old tools
{IF NEWTOOL=1}M204 S0 P1
{IF NEWTOOL=1}M304 S0 P1
{IF NEWTOOL=2}M104 S0 P1
{IF NEWTOOL=2}M304 S0 P1
{IF NEWTOOL=3}M104 S0 P1
{IF NEWTOOL=3}M204 S0 P1
^Turn on new tool
^set a P1 preheat without wait
{IF NEWTOOL=1}M104 S220 P1
{IF NEWTOOL=1}M104 S250 P1
{IF NEWTOOL=2}M204 S220 P1
{IF NEWTOOL=2}M204 S250 P1
{IF NEWTOOL=3}M304 S220 P1
{IF NEWTOOL=3}M304 S250 P1
^Move the printhead to the priming bay
{IF NEWTOOL=1}G1 X108.000 Y136.000 [current_Z_position] F9000.0
{IF NEWTOOL=1}G1 X108.000 Y161.000 [current_Z_position] F9000.0
{IF NEWTOOL=1}G1 X108.000 Y157.000 [current_Z_position] F9000.0
{IF NEWTOOL=2}G1 X118.000 Y136.000 [current_Z_position] F9000.0
{IF NEWTOOL=2}G1 X118.000 Y161.000 [current_Z_position] F9000.0
{IF NEWTOOL=2}G1 X118.000 Y157.000 [current_Z_position] F9000.0
{IF NEWTOOL=3}G1 X128.000 Y136.000 [current_Z_position] F9000.0
{IF NEWTOOL=3}G1 X128.000 Y161.000 [current_Z_position] F9000.0
{IF NEWTOOL=3}G1 X128.000 Y157.000 [current_Z_position] F9000.0
^Set temp to target temp
^Perge on the new tool 250 spans at a rate of 50
M55[new_tool] P250 S50
^Retract the plastic
M103
^Pause for 5 seconds
G4 P5
^Clean the print head
^set the overall flow control
M108 S20
^ToolChange Finished
^Set the cooling fan to 100pct
M106 100
CubeProTrio.factory
(1.18 MiB) Downloaded 465 times
Re: Scripting placeholder not working
I believe there were some changes to this in v3. Try [current_position_z] instead.
mmcginnis9272
JoeJ wrote:I believe there were some changes to this in v3. Try [current_position_z] instead.
I just tried changing all instances of [current_Z_position] to [current_position_Z] and it does the same thing. The placeholder is not being converted to the Z position.
Maybe it's case sensitive. Make sure you are trying [current_position_z] in all lowercase.
mmcginnis9272
JoeJ wrote:Maybe it's case sensitive. Make sure you are trying [current_position_z] in all lowercase.
That was the problem. The 'z' had to be lower case. so the working placegolder is [current_position_z].... just like you said.
Thanks for your help.
MichaelHerron
mmcginnis9272 wrote:So I have a CubePro Trio with the following in the Tool Change Script. When the Final .gcode is created, everywhere that [current_Z_position] apears, it is not being converted to the z position. The string [current_Z_position] remains in the gcode. Is there a trick to getting Simplify 3D to actually convert the placeholder into the Z value? I have attached my Factory file as well.
^Changing Tools
^ABS_Temp_220_250
^ABS_Temp_220_250
^2-ABS
^3-ABS
^Shut off old tools
^Turn on new tool
M103
G4 P5
M108 S20
M106 100
The good news with 3.0 is that you may not need any of this code anymore! Enabling the priming pillar on the cubepro should eliminate all of the tool-change wierdness that required all of this code.
mmcginnis9272
Seriously!? <said with both anger and excitment>
That would be cool..... <as I stare in to trash can at all the wasted jobs and filament lying there as I consider all of the wasted days I've spent on this.....>
