Hey, I'm having this issue.. My printer is an "ROBO 3D R1" and when i print i got some bad layers at top.
Here is an example
I was thinking it can be a slicing problem
cant find the extrusion multiplier. Solid infill underspeed was at 80% and switched to 70%KeyboardWarrior wrote:You may want to increase your Extrusion Multiplier (Extruder Tab) slightly, and also slow down your Solid Infill Underspeed (Other tab) to get a really nice finish on the top of your prints.
Thefilament dia is correct at 1.75mm.jimc wrote:You dont just set the multiplier to whatever you want. You need to print a thin wall calibration cube, and take measurements to set the multiplier. Start by setting the filament dia correctly as that works hand and hand with multiplier to calculate flow.
