So here is an example... I imported an obj file of a pumpkin to simplify in August. Everything went great. printed several copies
Decided that I wanted to print the pumpkin a bit larger so I imported the same obj file only to get the message "Cannot auto arrange. Largest part exceeds build dimensions". Cant get past that to even start with the edit process so that I could show you a factory file
. I tried several different obj files that I ran previously thru the program all resulting with the same message... I had a cow in stl file format and imported that... It came thru Hurray!!!! so I removed the cow as I really wanted to print the pumpkin and that is where the particles (triangles) are left that I see. Crazy I know
So I imported a monkey in STL format.. it came thru and I could see the triangles disappear so that is a good thing... removed the monkey and the left over triangles were left behind again from the monkey... Tried importing the cow in OBJ format this time and "Cannot auto arrange. Largest part exceeds build dimensions"... So I guess it hates my OBJ files and my STL files like to leave little bread crumbs! not sure if it is my Mac, or the update on simplify or if I'm just crazy
