dcphoto
Slicing Error
Having a problem getting S3D to properly slice a thin tube. Screen shots and the STL are attached. I thought it was just a display error, so I printed it, but it printed that way.
So I uploaded it to https://modelrepair.azurewebsites.net, and the repaired file slices the same way.
I've played around with settings, but nothing I do makes any difference. It always slices that way. For reference, other slicers don't seem to have a problem.
k40_superhead_1-3_fixed-2.stl
(103.7 KiB) Downloaded 453 times
Re: Slicing Error
It's the classic thin wall problem.
Do a search for "thin wall" on the forum and you'll find the answer to your question.....
dcphoto
Re: Slicing Error
Thanks. Was able to fix it once I knew what to look for.
