jamesarm97
Feature Request: Infill Speed option
Can we get an Infill speed option? Right now it seems it uses the main overall speed setting and only gets changed if the Cool or slowdown option is set and the layer time limit is hit. There is a speed option for everything else, why not add a % speed like the outer perimeter option.
Re: Feature Request: Infill Speed option
I thought the infill speed was the speed on which all other speeds are based....ie its the default speed.
If you want the infill speed to be a percentage....what do you want it to be a percentage of?
Agreed. The infill speed is the "default printing speed". They are one in the same.
Nandox7
Shouldn't be percentage but rather a absolute value like it is now for printing speed or non-printing moves.
This would be a nice feature and it would help speed up printing a bit, infill in interior to the part so lower precision isn't a issue as
it won't be seen.
If that precision is needed it would be aligned with the default printing speed as it is now.
