I recently started using Simplify3D with my M3D printer.
I have a problem where the edges were curling up. I treid many different things, sticky stuff and blue tape but nothing worked. One time I watched the first layer and noticed that its not printing well which would def seem to cause the edges to lift. I have attached an image.
So I started adjusting the bed level. Even when I lower the extruder way down, it strill makes the same problem. If I run the same file in M3Ds software the layer is very thick from over compensating the bed height.
So i checked in S3D to see if it object was not sitting on the plane, but it was. I tried without raft and had no change.
I'm out of ideas.
thanks
Jason
image: http://snag.gy/9AL6h.jpg
