Viceman
Help with triangle pattern print
Is there anyway to print the interior of the patterns with no "zigzag" pattern. I would prefer it fills the whole part with parallel style according the model edges. I attached the factory file so you can take a look. I have this problem with other parts too, when filling up narrow prints.
Trianglepattern_sample.factory
sample
(112 KiB) Downloaded 323 times
Viceman
Re: Help with triangle pattern print
No help with this? I have tried many many settings but it still fills the triangle lines with zigzag pattern?
The pattern has a bunch of walls that are about 1.5mm thick. So just set your extrusion width to a manual value of 0.38mm. That way you can fit 4 extrusions in each wall (4*0.38 = 1.52mm). Remember that you have 2 extruders, so you need to make this change for BOTH entries on the Extruders tab of your process settings.
If you don't do this, your extrusion width is too large, so it can't fit another perimeter in between those walls. That's why it was using the criss-cross fill.
Viceman
Thank you very much! Now I got it. I thought the extrusion width was something that you should not temper with. :roll:
