Kernfusion
Stopp heating bed before end of printing
Hello,
it is very help full when you can stopp the heating of the bed before end of printing,
by finish of printing you can faster remove the Model,
for example stopp heating the bed at Layer 11 before end of printing,
the Layer Number of stopp end of heat bed can variable chance 0-1000.
Re: Stopp heating bed before end of printing
You can set the bed temperature for any layer you want. So go into your process settings, click the Temperature tab, select your heated build platform on the left-hand list, and then enter whatever layers/temperatures you want. For example, if you want the bed to start at 60 degrees, but then turn off at layer 100, enter this:
Layer 1 - 60C
Layer 100 - 0C
Kernfusion
Yes I now,
but it is user-friendly, if you can use for all Models nearly the same parameter
and must not make for each Model a new process setting .
tmorris9
They could add something like Bed = 0 if layers left <5 but of course make it adjustable.
