LePaul
Ultimaker Original with Heated Bed profile
I'm new to Simplify3D and still learning the ways.
I have an Ultimaker Original I recently upgraded with the official Heated Bed Upgrade. (Nice upgrade!)
I thought it would be a simple addition to the Ultimaker Original but wow....so many tabs and check boxes. I decided to stop and ask :)
(The Ultimaker Original is different than the Ultimaker Original +. Different electronics, so that wasn't a good option)
Thanks!
Re: Ultimaker Original with Heated Bed profile
Don't you just go to the Temperature tab and click "Add Temperature Controller" and then use the radio buttons to select that it's a "Heated build platform"?
Then you can just copy all of the other settings from whatever your extruder was using (of course, changing the setpoint temperatures as needed)
LePaul
Well a few things...
1) Totally new to Simplify 3D
2) Lot's of sub menus! Not sure what does what!
3) Not seeing the option(s) you mention
neotko
Even with different electronics the umo+ and umo +bed are the same on x/y/z size and speeds, motors, etc. It will work just the same.
LePaul wrote:Well a few things...
If you're totally new, I would strongly suggest watching their video series. It was really helpful when I got started: https://www.youtube.com/playlist?list=P ... DJpQBVf-Ss
And I'm not sure what else to tell you about how to find those options. I pretty much wrote out every step... Perhaps you aren't familiar with any of the process settings yet?? (you click the "Edit Process Settings" button in the lower left to get there)
LePaul
I'm working my way through those.
Perhaps I was being a little lazy, hoping a profile for this printer already existed 8-)
