I'm using stock settings for a Makerbot Rep 2
As I understand it, the Makerbots rep 2 sense temperature different than other printers, so the 230 temp is correct for PLA.
It doesn't matter if I print 1 or 4 of these parts or parts like them... When the layer get's small, the extrusion stops and then starts back up again later. It's the the nozzle is getting clogged up and then releases later on in the build.
I went through the printing guide https://www.simplify3d.com/support/prin ... e-of-print and tried the suggestions under stops extruding. But they didn't address this correctly.
I've tried many things including:
No Fan (less Fan)
Over Extruding
Higher and lower temps
I am at a complete loss here... Please help.
