siwek
Jog Control Settings WHILE printing
There MUST be a trick or setting to making "Jog Control" adjustments while actively printing. they work for some cycle (G-Code) and the instantly revert. Folger Kossel 2020.. Oterwise well tuned…except when I use the scissors to cut some threads :| :|
Its curious behavior. Is it G0 vs G1?
Help me Obi Wan Canobie. You are our only hope……..zzzzzzzzzzip
Re: Jog Control Settings WHILE printing
When you say jog control adjustments, do you mean actually clicking on one of the jog buttons during a print (for example move +X by 10mm)?
That isn't going to stick if you are using absolute coordinates, since the next command will move back to an absolute position. I would also think this is very dangerous to do while a print is running. What's making you want to use that during a print?
siwek
CompoundCarl wrote:When you say jog control adjustments, do you mean actually clicking on one of the jog buttons during a print (for example move +X by 10mm)?
Thanks. Yes WHILE printing clicking .1mm to compensate for a SNAFU, when something bumps the carriage, like a cat or a pair of forceps :-P lesson learned
