Dear all,
since several days now I work with S3D (3.1). The preview is really helpful to analyze the print process in advance.
What is really annoying is that I cannot change settings like 'Fill density', 'No. of perimeters, etc. without closing the preview and entering the process settings and re-entering the preview window.
What I would like to have is a side-by-side view of process settings and preview window.
This would make it much more easy if I change e.g. 'No of perimeters' I immediatley could see what effect it has.
Now I have to switch forth and back between both windows which is not very comfortable.
In the meantime it would be also great if S3D could remember the last layer I watched / examined.
E.g. if I have an issue on layer 47 I quit the preview window. Then I do some tweaking in the process window and open the preview again to see if the tweaking has brought some improvement. But the preview shows the last layer every time so I have to move the sliders back to layer 47 which is really time consuming and disturbes the tweaking / checking preview process.
Lets say one day we will have this side-by-side view of process settings and preview. Then each modification of any process setting will cause that S3D recalculates all layers. If it is possible (maybe by activating a new option 'calculate only current layer') the preview should calculate and show only the one layer I am intereseted in. So I immediately can see if the tweaking causes the right result in the specific layer.
Thanks...
