Which command are you using to enable the fan? As far as I know FF Creator Pro is also using a sailfish firmware, so gpx is mandatory to create the x3g files.
What's set in the firmware options?
(just a hint where to look for. These are the values I use for a modified malyan m180, so no one should just copy these
bye,
para
