davedfx
Show, hide supports in preview
I would like to show or hide support in the preview mode. This makes for easier debugging of problems with supports.
Re: [Feature Request] Show, hide supports in preview
If you go under tools then select support you can show, hide, add and remove support.
davedfx
In preview mode I can only show or hide Table, Tool, Rapids, and retracts but not support.
Oh yes duh. That preview lol. Yeah that shows only the exact lines the extruder puts down. I thought you meant for setting up your model on the build plate. Sorry
Boni
+10
I know that is not easy to do because the "previewer" reads a G-Code file but maybe tagging it with a comment should be able to show it with different color/texture and hide as well.
Cheers,
