Is there a step by-step walk-through for using the SD card?
I do not see a "print to file" or "save to SD card" ?
I figure I must be missing something obvious.
So the idea is that the firmware on the RAMBO is able to digest .gcode files?Simplify3D wrote:Just click the Prepare button after you have the models and processes all setup and then choose the SD card as the destination. Prepare is essentially the button to slice and export the G-Code. We also tried to put helpful tooltips all through out the program, so you can try hovering the mouse over a UI element to figure out what it does if it isn't clear.
