brian442 wrote:It looks to me like it isn't retracting because you disabled "retract between layers". So that point you highlighted is the last thing printed on each layer. So just enable that option if you want a retract at the end of each layer.
I don't know if this is related to the thread above at all, but perhaps some of those people also had this option disabled.
That option is to force a retract every layer, and it shouldn't be necessary to generate a retract over open space even at the end of a layer.
If the piece off to the side was part of the model instead of a support S3D would properly generate a retract.
Turning on "Force retract between layers" is fine in this case due to the many shells, but it does generate an extra retract every layer and for some models that causes the blobs I wanted to eliminate.
