AK_Eric
Respect endstops in RepRepFirmware when jogging?
I'd posted this question over on the Duet3d forums (home of RepRap Firmware), currently not coming up with much, thought I'd check here too.
https://www.duet3d.com/forum/thread.php?id=2617
Anyone who uses RepRapFirmware know how to configure S3D so that its jog controls (via the Machine Control Panel) will respect the endstops? My machine homes just fine when pressing the home buttons.
But say, if it's 10mm away from the X endstop, and I accidentally hit the "Jog -100 on X" button, it'll crash right into it making horrible sounds.
Presumably this is because S3D is sending a
G1 X-100
not a
G1 S1 X-100
to the printer: RepRapFirmware suppoprts an additional 'S1' parameter that tells it to 'detect endstops' during G1 motions.
And S3D's 'Firmware Configuration' window has no special field for issuing G1 commands.
https://duet3d.com/wiki/G-code#G0_.26_G1:_Move
I've learned to be 'very careful' when using the jog controls, but it still happens to me from time to time: Anyone come up with a solution? Am I missing something basic here?
Thanks!
Bots:
Makerbot Replicator 2x / Sailfish on Mightyboard
Custom C-Bot / RepRap Firmware on RADDS
Custom Tevo Little Monster / RepRap Firmware on Duet
AK_Eric
Re: Respect endstops in RepRepFirmware when jogging?
I can 'sort of' answer this : If you set a M208 in your config.g (which sets your axis maximums), and then home, after the homing operation, the min\max values are set, and it won't go crashing around into things. Not perfect, but better than nothing.
If there's a better way to do it (so you don't crash stuff if you jog without homing first), I'd like to hear it though.
Bots:
