jstrom
S3D 4.0 and MacOS High Sierra ?
Has anybody else noticed any issues with S3D 4.0, FlashForge Dreamer latest firmware revision and MacOS High Sierra?
I've had previously no issues printing the same model with S3D v4 on Mac OS Sierra. I upgraded to High Sierra when it was first released and only tried printing today again for the first time since that update...
Overall communication with the printer seems a bit iffy. The file generated contains errors and cannot be correctly printer, in fact it stops after only a few percent. This is the same case for USB direct print or generated and stored on the SD card...
The Fusion 360 generate .STL is fine. Flashprint 19.1 seems to be able to parse the generated gcode file and print the model, although not as well as the first model I printed prior to the upgrade.
I can't figure out if it's an issue with High Sierra or S3D v4... Any suggestions?
