Hi all i have aproblem with my Wanhao D6 and S3D. If i start a print the printer heat up, home axes, extrude filament and now retract so much that when the print starts no filament is in the printhead. on large objects with long outlines it is no problem but with small parts it sucs. The printer do this with te original firmware and the marlin firmware. With the original slicer (c***) he don´t.
This is the start code from S3D :
G28 ; home all axes
G92 E0 ; zero the extruded length
G1 Z10 ; lower
G1 E20 F200 ; purge nozzle quickly
G1 E10 F60 ; purge nozzle slowly
G92 E0 ; zero the extruded length again
G1 E-1.5 F400 ; retract
G1 X170 Z0 F9000 ; pull away filament
G1 X180 F9000 ; wipe
G1 Y20 F9000 ; wipe
G1 E0 ; feed filament back
I solfed that problem with pressing the the filament release when the extruder retracts but thats not a good way because it clamps the x and y axes a little bit.
I hope someone can help me.
