shasselberg
[ADDED] Network Printing
Will it every be possible to print directly over the network to network-enabled printers, either WiFi or ethernet?
ddhawk
Re: Network Printing
Add me to this request. Dremel 3D45 could use support for printing over WiFi.
argh
Make that 3 for Dremel 3D45.
I am so incredibly disappointed that the printer is "supported" but I can't use the wifi.
Thanks for your feedback and suggestions. I believe the original intention of this thread from 2017 was to add network printing support in a more general sense. However I'll document your specific requests for 3D45 network printing support for our development team. In addition, I'll continue to monitor this thread for other network printing requests.
markauskas
Support for Duet3D boards would be great as well.
Thanks for including the Duet3D Wifi / Ethernet as a mentioned printer board that supports network printing. Which revision of the board do you have? I'll add this to the feature request's documentation.
Ret
I second the support for network printing with Duet boards.
hectorri
+1 to Duet3d Support.
markauskas
S3D-Jake wrote: Mon May 13, 2019 2:01 pm Thanks for including the Duet3D Wifi / Ethernet as a mentioned printer board that supports network printing. Which revision of the board do you have? I'll add this to the feature request's documentation.
I have a Duet 2 Wifi v1.03
BobMinteer
I am in the midst of converting my DaVinci Pro 1.0 to Duet3D v1.04.
I am always happier with my prints when when using S3D rather than the XYZ slicer.
So... I am all for supporting WiFi printing for RepRapFirmware / Duet.
