gpau
Z axis at the end of the print goes to the left and not to t
hello, what setting do I have to do to return the Z axis to the home position.
Now when the print ends, the Z axis moves to the right.
Thank you
Re: Z axis at the end of the print goes to the left and not
It will be a gcode statement in the Ending script for the process you are using.
gpau
Where I go to see the g-code
After importing the model and putting all settings go to
Prepare To Print
this shows the preview of the print and on left side the button
Save Toolpath To Disk
Click this button and a file will be stored on choosen folder.
The File has the extension *.gcode when this format is choosen in the menue >>> Process Setting >> Scripts (if not, change it!)
Alternatively you can copy in menue Scripts the Starting- and Ending Script or better
you attache here your FactoryFile when readed this: https://forum.simplify3d.com/viewtopic.php?f=8&t=2367
H.
gpau
OK thank you very much
