emaayan
Simply 4.0 started crashing on startup
hi... until recently it worked fine, now each time i start it up it crashes, i've had some power outages recently, but everything else works fine.
rrdavis
Re: Simply 4.0 started crashing on startup
You could try following the instructions here:
https://www.simplify3d.com/support/faq/#faq-4628
emaayan
thanks the logs says this:
Faulting application name: SIMPLI~1.EXE, version: 4.0.0.0, time stamp: 0x597095a0
Faulting module name: Qt5Gui.dll, version: 5.6.2.0, time stamp: 0x594bc8af
Exception code: 0xc0000005
Fault offset: 0x000000000007a6b6
Faulting process id: 0x4c8
Faulting application start time: 0x01d396aa29e3b8ba
Faulting application path: C:\PROGRA~1\SIMPLI~1.0\SIMPLI~1.EXE
Faulting module path: C:\PROGRA~1\SIMPLI~1.0\Qt5Gui.dll
Report Id: 6b6cb18c-029d-11e8-b634-00090ffe0001
rrdavis
Looks like you're using 4.0.0. Try logging into your account on the S3D website and download 4.0.1. That may solve the issue.
If not, the try following the link I already posted above.
