beemergb
TronxyX5S and Simplify 3D compatibility
Hallo there , fighting my way to get my TronxyX5S to run ! Have found a lot of my inbuilt faults ,small but deadly . Now I have another problem , I have put in the G codes for TronxyX5S ,330x330x400 enterd it all , and went to X3G and it tells me this is for Makerbot Printer only .Does this mean that Simplify 3D does not automatically Support my printer .And is the reason when I use Config Wizard the thing goes nuts ! I mean first Corner it Levels then seems to jam and huff and puff but no leveling Corner to Corner . Hope you can help .Thank you Harry
KDan
Re: TronxyX5S and Simplify 3D compatibility
I would avoid the config wizard based upon what you are saying. The stock X5S uses Marlin firmware which works with straight G-code, not X3G. If that is wrong, it's possible a lot of other things could be wrong too. I'd go through he configuration process manually. It's not that hard.
