LTH
Infill Question
I have a friend that's asked me to print him a part for his American Harvest Oven that has broke. I'm thinking I'll have to do multiple process's to accomplish what I'm needing but not sure how to go about it to save some print time. From 72 to 83mm it needs to be 100% infill. Every setting I've played with shows between 13 & 14 hours. I've attached the factory file. Any help would be appreciated. Thx
American Harvest Oven Thing.factory
(35.91 KiB) Downloaded 220 times
Re: Infill Question
Upping the layer thickness to .25mm and the extrusion width to .48mm drops the time down to just over 10 hours for a starter.
While you're at it, change the support angle to 45 degrees. That will give better support.
LTH
Re: Infill Question
Thx Doug I'll give it a try.
