kevin
Slicing Problem
I have problem slicing this model in S3D. It just generate a few toothpath in the preview.
I tried same model in cura and toothpath generated is ok.
Can anyone comment what is the problem? Thanks in advance ;)
Cover.stl
(1012.97 KiB) Downloaded 182 times
KeyboardWarrior
Re: Slicing Problem
I used an online repair service and sliced the file attached, it worked as should (using the Robo 3D profile)
Cover_fixed.stl
(2.35 MiB) Downloaded 164 times
Rebekah_harper
Re: Slicing Problem
I think the problem is that your part has no volume.
here is your part in S£D with the crossectional view. and to me it looks like it was made out of a mesh and isn't a solid.
if there is no mass or the walls are too thin for your nozzle to deal with it won't give you a preview nor would it print.
AndersE
Re: Slicing Problem
I think i must say something here..
The model slices in cura and slic3r without problems..
I think there are too many quirks in s3d still that need to be fixed.
