I'm trying to use the CF-XT20 filament, with Robo3D Printer, I have the filament set at ABS, tho I'm sure that setting doesn't change anything
It's suggested to use 40-70mm/s extrusion with this filaments, I can't find a setting that allows me to limit the speed
Either I have to correlate the X/Y/Z speed somehow and reduce them, or correlate the default extrusion speed and reduce the print speed from the override speed knob
I would appreciate some advice, but as it seems, Simplify 3D can't just simply halt the print speed - or set the extrusion speed to a constant and calculate the other speeds based on that
(There is also the default print speed, however I interpret that one as the movement speed, am I supposed to set that one at 40-70?)
