adamfilip
Feature Request : Mouse Ears
I would like to be able to easly add a Brim or Mouse ears to spefici areas of the model to help prevent curling. or even better for it to be able to tell where curling might occur and automatically add them to those areas.
Tesse
Re: Feature Request : Mouse Ears
+1
JoshuaYates
I'm not sure there would be a good way to know where about's a model would start curling as having your bed slightly out could be the issue so the software wouldn't be able to accommodate for this. Isn't it possible to brim the hole model by setting the distance from part at 0mm?
adamfilip
yes but removing a brim for an entire model is a pain. easier to just remove a few disks.
JoshuaYates
Well you can kind of cheat and do this using the support function. It looks like it might work but not sure as haven't tried it.
Here are some settings you could try.
Mouse Ears
Mouse Ears
Support Settings
Support Settings
Support Placement 10mm
Example 3.png (8.61 KiB) Viewed 3311 times
