Usually I only print artistic stuff that dont need to be exact in dimensions as the STL files. But I did had a lot of issues with some mechanical prints, and thanks for the help of the user horst.w we got a pretty good workaround. But I would like for the simplify3d team to investigate this and try to do a fix.
If we had a "scale to percentage" function, besides the horizontal compensation, this could be a good "workaround" ( not a fix ), since we have to scale the objects everytime we add them to the plate. and the horizontal compensation, does make the holes wider if using negative values, but we have to scale the object up, in other to compensate it.
below is the link to the original topic, full of information that might be useful for you guys.
viewtopic.php?f=9&t=1229&start=10
if you need I am available to help with more data and tests.
Thanks in Advance,
Antonio Santos
