... Does not work.
Please look at the video found by URL - https://drive.google.com/file/d/0B9i19W ... sp=sharing and the attached factory file.
As you see 3DSimplify 'almost' decides to not overheat my PLA plastic... 3DSimplify frequently find it meaningful to put down 2 layers of plastic, in the same area, even when it has a possibility of going to another area and help the PLA to cool down more.
The “Print islands sequentially without optimization” option is selected – why do you slicer behave like this and how can I avoid it? This issue is a direct show stopper which might prevent us from printing detailed parts.
In this case my print is ruined by warping, from the fact that plastic is put upon non settled plastic, producing a ridge at every 17th layer.
I guess this is a bug – can you confirm?
