kyphur
S3D pausing during print on Maker Gear M2
During a print it will pause numerous times. The only way to get it to keep going is to hit pause and then unpause it. It seems to do it on the one at work and the one at my house.
Re: S3D pausing during print on Maker Gear M2
i will assume you are running windows 10 and you are printing via usb? this is a common issue that has been talked about over and over again. windows has yet to correct the issue. if your on windows 10 you need to print via sd card.
kyphur
Computer at home is W10 but the ones at work are W7.
