During a print it will pause numerous times. The only way to get it to keep going is to hit pause and then unpause it. It seems to do it on the one at work and the one at my house.
i will assume you are running windows 10 and you are printing via usb? this is a common issue that has been talked about over and over again. windows has yet to correct the issue. if your on windows 10 you need to print via sd card.
