One post on the FFCP forums mentioned to "slow down your X/Y fill and speed rates"... but the only thing I can find in S3D is the "non fill X/Y rates"
Is this correct?
Thanks!
Just a little math... default speed * percentage = actual speed.wfcook wrote:I sure wish I could just set the speeds directly instead of having them all be relative to the infill speed.
If you want to use mm/s, look in Tools -> Options... change from mm/min to mm/s.JasonA wrote:Yeah, I'm used to RepG's speed of 40-90 "mm/sec"so when I translated that over to S3D... I kinda bonked that up
DUH!
So I'm trying 2400mm/min rate (60mm/sec) and leaving everything on 100% and dialing down from there for what I need.
Ultimately I think I need to do the Z wobble bed upgrades to the FFCP because I can see the slop during moves. Something my "Woody" has no issues with.
Thanks for the tips! I'll post a pic here in a bit
No, not just a little math, because if I want to change the infill speed I have to recalculate all the percentages every...single...time. It's a royal pain in the butt. And it frankly makes no sense to have the perimeter speed and the infill speed proportional to each other. The effects of speed change are nonlinear.KC_703 wrote:Just a little math... default speed * percentage = actual speed.wfcook wrote:I sure wish I could just set the speeds directly instead of having them all be relative to the infill speed.Or desired speed / default speed = percentage
